14 years ago --- Quote Start --- At my job I spend my day verifying hardware (mixed signal ASICs), and I typically use Python to extract and process data from the hardware, Scopes and other test equipment....hence my preference to move data over to Python :) --- Quote End --- Yeah, I understand :) --- Quote Start --- I'll look into writing a Tcl script to parse the wave.do file as I mentioned above, I'll drop back once I get it figured out. --- Quote End --- I still think you'd be better off generating the file directly from an HDL language ... Note that Modelsim-SE does support Tcl/Tk, so if you have that at work, you can always play with Tcl/Tk in that version of Modelsim. Cheers, Dave
