modelsim_ae licensing not working
Hello, I am an Intel Intern trying to get modelsim altera edition working properly on Ubuntu 16.04. I have the complete Quartus Prime 18.0 Standard Edition and I have Quartus working and the licensing is set up. However, when I attempt to run modelsim, I get an error about the licensing.
First, I tried to run modelsim through the Quartus GUI, which generated the attached report.
Then, I attempted to run it through command line with ./vsim and this produced the following output:
$ ./vsim
Unable to checkout a license. Make sure your license file environment variable (e.g., LM_LICENSE_FILE)
is set correctly and then run 'lmutil lmdiag' to diagnose the problem.
Unable to checkout a license. Vsim is closing.
** Fatal: Invalid license environment. Application closing.
So I checked to make sure my variable existed:
$ echo $LM_LICENSE_FILE
Then I used lmutil as the above output suggested (I copied the directory I ran this command from too):
~/intelFPGA/18.0/modelsim_ae/linuxaloem$ ./lmutil lmdiag
lmutil - Copyright (c) 1989-2014 Flexera Software LLC. All Rights Reserved.
FlexNet diagnostics on Mon 8/20/2018 14:53
License file: [email protected]
"6AF7_00DD" v2019.04, vendor: alterad, expiry: 1-jan-0
License server: fmylic7008.fm.intel.com
floating license no expiration date
This license can be checked out
And this is where I felt stuck. It appears that the diagnostic tool does not believe anything is wrong, so what could be causing this? Any assistance would be greatly appreciated.
Best Regards, Alex
Hi Milleral,
If you're an Inten at Intel, kindly contact your supervisor related to this issue or
can you provide your Intel e-mail ID?
- CalvinJoaz_P_Intel
Contributor
Hi Milleral,
- Alexander_M_Intel
Hello Calvin, my supervisor is the one that advised me to post my issue on this forum. My email ID is Removed
Thanks, Alex
