11 years agoModelSim 10.3d Create/Edit Waveform
I am having problems creating a waveform in ModelSim Altera SE 10.3d. I am trying to follow the tutorial "Getting Started with Quartus II Simulation Using the ModelSim-Altera Software" but I ...
11 years agoHi,
Just wonder if you could workaround by generating the clock waveform by coding it in the test bench? I have not tried the steps in the tutorial but generally I will use test bench for clock generation.
