Modelsim - greybox netlist file
- 4 years ago
In the above, I did not regenerate the library (launching the simulation library compiler). After doing so, the correct path names were present and the simulator was properly launched. Now that I have Modelsim running, I need to figure out why the generated IP's simulation files are not working. Example is a simple PLL, where the clock out is not toggling.
Sheng,
Trying your method of not including the "greybox".v files in the Modelsim script file, it appears that Modelsim does attempt to open a simulation file, but the subdirectory for the file Modelsim attempts to read does not exist. See below:
The directory: ../qdr_d_ddio/altera_gpio_core20_191/ was never created by the IP generator. The directory ../qdr_d_ddio/altera_gpio_core20_2000 was created.
Forgot to add Kudo's. Thanks to both of you for your help.
