Modelsim - greybox netlist file
- 4 years ago
In the above, I did not regenerate the library (launching the simulation library compiler). After doing so, the correct path names were present and the simulator was properly launched. Now that I have Modelsim running, I need to figure out why the generated IP's simulation files are not working. Example is a simple PLL, where the clock out is not toggling.
The box is not greyed out, but after generating the IP, with the box clicked, an associated "greybox" .v file is not created.
When you say "you can use the regular top-level files for simulation", what IP file generated file do you include in the modelsim .do script in place of
vlog -vlog01compat -work work ../UP_COUNTER_IP/UP_COUNTER_IP.v
vlog -vlog01compat -work work ../DOWN_COUNTER_IP/DOWN_COUNTER_IP.v
