Modelsim - greybox netlist file
- 4 years ago
In the above, I did not regenerate the library (launching the simulation library compiler). After doing so, the correct path names were present and the simulator was properly launched. Now that I have Modelsim running, I need to figure out why the generated IP's simulation files are not working. Example is a simple PLL, where the clock out is not toggling.
I'm using 22.1 Pro and I see the file in ip/<IP name>/synth for an IP I just created.
Maybe we're talking about two different files.
- SteveRiley4 years ago
Here is a greybox file that is included in the example and outlined in the user guide. In the later versions of Quartus that I have tried (Prime Pro 20.4 and 21.2) a file of this type/content is not generated at all. If the IP simulation file has changed structure & location in the later versions, then how is the Modelsim script (image above) modified to use them
