Modelsim - greybox netlist file
- 4 years ago
In the above, I did not regenerate the library (launching the simulation library compiler). After doing so, the correct path names were present and the simulator was properly launched. Now that I have Modelsim running, I need to figure out why the generated IP's simulation files are not working. Example is a simple PLL, where the clock out is not toggling.
Stupid question: are you just looking in the ip directory itself or in the folder created in the IP directory named after the IP you created? And then in there are you looking in the synth (or sim) directory?
I searched all the subdirectories. There are no files created like the greybox files included with the example. I am thinking that the simulation file name/structure/location has changed since the user guide was written.
