SteveRiley
4 years agoModelsim - greybox netlist file
I followed the quick start guide and the example project (ModelSim* - Intel® FPGA Edition Simulation Quick-Start) and it work fine as outlined. Using this as a template on a different project, the ...
- 4 years ago
In the above, I did not regenerate the library (launching the simulation library compiler). After doing so, the correct path names were present and the simulator was properly launched. Now that I have Modelsim running, I need to figure out why the generated IP's simulation files are not working. Example is a simple PLL, where the clock out is not toggling.
ShengN_altera
4 years agoHi,
Any further update on this? Have your problem resolved?
Sheng
- SteveRiley4 years ago
The problem has not been resolved. I am creating IP from the IP Catalog, generating the code for them (Generate HDL button in the parameter editor), and not getting the files generated.
