Modelsim - greybox netlist file
- 4 years ago
In the above, I did not regenerate the library (launching the simulation library compiler). After doing so, the correct path names were present and the simulator was properly launched. Now that I have Modelsim running, I need to figure out why the generated IP's simulation files are not working. Example is a simple PLL, where the clock out is not toggling.
Yes.
The IP files (list above excluding the test bench and top level design).
Yeah, the IP Parameter Editor creates those after you parameterize an IP.
- SteveRiley4 years ago
I am using 20.4 and those files are not being generated.
- sstrell4 years ago
So you're creating IP from the IP Catalog, generating the code for them (Generate HDL button in the parameter editor), and you're not getting the files generated? If not, there is something very wrong with your Quartus installation.
