SteveRiley
4 years agoModelsim - greybox netlist file
I followed the quick start guide and the example project (ModelSim* - Intel® FPGA Edition Simulation Quick-Start) and it work fine as outlined. Using this as a template on a different project, the ...
- 4 years ago
In the above, I did not regenerate the library (launching the simulation library compiler). After doing so, the correct path names were present and the simulator was properly launched. Now that I have Modelsim running, I need to figure out why the generated IP's simulation files are not working. Example is a simple PLL, where the clock out is not toggling.
sstrell
4 years agoYou mean like ClockPLL.v? That's a top-level file for the IP generated when you create the IP using the IP Catalog in Quartus. That becomes part of your design.
- SteveRiley4 years ago
Yes.
The IP files (list above excluding the test bench and top level design).
- sstrell4 years ago
Yeah, the IP Parameter Editor creates those after you parameterize an IP.
I am using 20.4 and those files are not being generated.
