SteveRiley
4 years agoModelsim - greybox netlist file
I followed the quick start guide and the example project (ModelSim* - Intel® FPGA Edition Simulation Quick-Start) and it work fine as outlined. Using this as a template on a different project, the ...
- 4 years ago
In the above, I did not regenerate the library (launching the simulation library compiler). After doing so, the correct path names were present and the simulator was properly launched. Now that I have Modelsim running, I need to figure out why the generated IP's simulation files are not working. Example is a simple PLL, where the clock out is not toggling.
sstrell
4 years agoLink to the guide you are referring to?
