11 years agoModelsim - Error loading design - vsim-3170 - could not find
Hi there, when i try to simulate my design, i receive the following msg: vsim -gui "+altera" -l msim_transcript -do "filename_run_msim_rtl_vhdl.do" # start time: 23:18:28 on mar 01,2015#...
11 years agoThe error is saying that the specified design unit could not be found for loading. First, you may want to restart the simulator and re-execute the FILENAME_run_msim_rtl_vhdl.do to see it helps. You may also need to ensure the design unit has been compiled into correct library and that library is mapped correctly. That will help if you may attach the testcase here for debugging further.
