12 years agoMixing OpenCL kernel with VHDL Netlists
Hi, Is it possible for the output of an OpenCL kernel to reside in the same FPGA as a VHDL netlist? For example, could I implement an algorithm in OpenCL and a display driver in VHDL? The intentio...
10 years agoThanks BadOmen. The problem that i am trying to solve is to have some high-bandwidth/low-latency communication between the CPU (C++) and the FPGA (OpenCL) on a SoC. What would you recommend as the best approach to the solution. Currently, i copy the data in a circular buffer as well as the endpoints (start/end) to SDRAM, and have the CPU poll over the endpoints to check for data produced by the FPGA. This, as expected is quite slow. I have two approaches in mind to speed it up -
1) Relying on physical addresses mapped in the FPGA-2-HPS and HPS-2-FPGA bridges. I am not sure if there is a region of the physical address space that is mapped to a buffer that i can use for data exchange. As far as i have read, there are specific addresses for IO devices, but nothing for data exchange. 2) Relying on the coherency mechanism (ACP) to communicate the endpoints and use the SDRam for communicating the actual data. As you might have guessed, i don't have much experience in FPGAs, so any help will be appreciated. I am looking for something that works well with relatively medium effort. Thanks,
