12 years agoMixing OpenCL kernel with VHDL Netlists
Hi, Is it possible for the output of an OpenCL kernel to reside in the same FPGA as a VHDL netlist? For example, could I implement an algorithm in OpenCL and a display driver in VHDL? The intentio...
12 years agoYes, I see the point of using channels and the simply kernel as you have described it, as it means it would limit the movement of data between the FPGA and the host. I will explore both avenues. Also, I have sent you a private message.
Cheers
