mbraniff
5 years agoMissing source | Quartus
I trying to make a make a system takes in a 3 bit line and flips put to a specific bit, like two's complement. I am struggling to reconstruct my bit bus after manipulating my bits. Specificall...
sstrell
5 years agoI'm not sure why you are using NAND gates like that instead of simple inverters, but the outputs of those NAND gates are single bit and you're trying to turn them into multi-bit busses. You can't just combine bits together with wire connections like that.
