missing lib file libedit
Which Red Hat are you using? 4,5,6?
You can find the libedit 32 bit file for Red Hat here:
https://rpmfind.net/linux/rpm2html/search.php?query=libedit&submit=Search+...&system=&arch=
Let me know if the problem persist.
Regards.
- SKinz7 years ago
So, I have two big servers, lots of memory multiple 3.6G cores, and a laptop. The servers run Ubuntu 16.04 and the laptop runs 18.04. After installing the :136 files, (though why at this point 32-bit support is required is beyond me) and creating some links to libraries that are not installed as part of those 32-bt libraries, libedit being one of them, I have the Quartus 19.1 running under 18.04. But, it requires python3.6 which is not in the 16.04 repository so I need to find a way to install python3.6 on ubuntu 16.04 since I cannot upgrade these machines at this time to get 19.1 running.
At this time it appears Quartus 19.1 really doesn't support debian installations, at least not without a few more tweaks not listed. I'll let you know if I get it running under ubuntu 16.04 LTS.
Skip
- EBERLAZARE_I_Intel7 years ago
May I know which are the other 32-bit libraries that are required to be install under 18.04?
The issue seems to be similar case for Quartus 18.1 on ubuntu 18.04 LTS:
https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/tools/2019/why-does-my-quartus-prime-18-1-fail-to-run-on-ubuntu-18-04-lts-.html
Apologies for the inconvenience.
Regards.
