17 years ago
mismatched ports with Megafunction RAM
I trying to implement a dual port RAM using a megafunction. Using Quartus, I can compile a simple RAM and a set of RAMs constructed in a single block, but when I use one of these blocks in a larger design, I get an error:
G primitive "memory_64k_by_8_MRAM:inst2|altsyncram:altsyncram_component|altsyncram_se02:auto_generated|ram_block1a7" has mismatched parameters for port Port A, Data In File: ../Higher_level_mem_Block2/db/altsyncram_se02.tdf Line: 44
36 SUBDESIGN altsyncram_se02
37 (
38 address_a[15..0] : input;
39 address_b[15..0] : input;
40 clock0 : input;
41 clocken0 : input;
42 data_a[7..0] : input;
43 data_b[7..0] : input;
44 q_a[7..0] : output;
45 q_b[7..0] : output;
46 wren_a : input;
47 wren_b : input;
48 )
Any clues as to why I'm getting this error. Thanks in advance with your help.
1 Reply
    As it suggest there must be some mismatch in top and low level port parameter, you can also use Quartus II's help by using mouse click on error you have and then right click and then help.
