15 years agoAre you sure TimeQuest is doing this? I'm pretty sure:
1) The dynamic delay chains all power-up to the shortest delay when the dynamic inputs are used 2) TimeQuest analyzes it this way. I just analyzed an I/O with dynamic delay chains(SIV output) and saw this occuring. Also, Minimum Pulse Width checks are usually against a single point, i.e.: - An I/O port that is clocked faster than the standard on it - A memory block running faster than the max rates in the handbook - The PLL reconfig clock going faster than it should Perhaps you're running the I/O config clock faster than allowed?
