8 years agoMinimum II of 2 but HTML report has no further information
I have a single work item kernel with a local mem used for a ping pong buffer with a form similar to the following: local float __attribute__((bankwidth(4), ...
8 years agoBy using indirect addressing, you are preventing the compiler from properly determining whether there is any load/store dependency in accessing the mem buffer in the loop or not; hence, the compiler assumes the worst case and enforces the highest II to ensure correct functionality.
