11 years agoMigrating from MegaWizard to IP catalog issues
I have installed QII14.1, and found that it seems remove MegaWizard and insert IP catalog. Now, i used QII14.1 open my previous project, however, i don't know how to edit the IP (for example, PLL) im...
11 years agoHi,
Starting from QII 14.0, the IP Editor has replaced the previous megawizard. So, you could not use megawizard to edit your file in QII 14.1. As a workaround, you may try archive your older QII version project ie 13.1 and then use QII 14.1 to un-qar the project QAR. By default, the QII 14.1 will perform auto IP upgrade and then you could use IP Editor to edit your IP instances.
