Message ID: 18591 Error: Can't recognize the flash device that attached to device 2. The flash device is not supported by Quartus prime software. Device: ARRIA 10 GX 10AX115S2F45 Software: Quartus pro 17.0 and Quartus pro 18.1
- 7 years ago
Hi Wolfgang
Thanks for replying.
I have tried what you have suggested but unfortunetly nothing worked, until now i still have that annoying message popping up every time i want to upload a file onto the ARRIA 10.
I found a way around this problem by bypassing the MAX FPGA 5M2210Z, i delete the Max FPGA 5M2210Z and then send the 10AX115S2F54 right up before the 10X115S2 FPGA. Make sure, there is a tick on Program/configure. Click Start to install.
Hi Wolfgang
Error(18591): Can't recognize the Flash device that attached to device 1. The Flash device is not supported by Quartus Prime software.
I have similar issue in programming Stratix 10 FPGA. Please find below the screenshot of the window and suggest a solution for this.
