OThys
7 years agoMessage ID: 18591 Error: Can't recognize the flash device that attached to device 2. The flash device is not supported by Quartus prime software. Device: ARRIA 10 GX 10AX115S2F45 Software: Quartus pro 17.0 and Quartus pro 18.1
Could you please assist? I am trying to upload a bit file, when i lunch the autodetection of the device i automatically get this error.
- 7 years ago
Hi Wolfgang
Thanks for replying.
I have tried what you have suggested but unfortunetly nothing worked, until now i still have that annoying message popping up every time i want to upload a file onto the ARRIA 10.
I found a way around this problem by bypassing the MAX FPGA 5M2210Z, i delete the Max FPGA 5M2210Z and then send the 10AX115S2F54 right up before the 10X115S2 FPGA. Make sure, there is a tick on Program/configure. Click Start to install.
ShafiqY_Intel
7 years agoHi OThys,
Below are the suggestion workarounds you can try. You can try either one of these suggestion:
- Set your SW4 switch to default position setting. (refer to attachment picture)
- Set Switch 1 (MAX V) to ON position. Switch 1,3,4 set to default position setting. (refer to attachment picture)
- Changes your TCK frequency to 6 MHz (default value).
I hope this will help.
Thanks😉
