12 years ago --- Quote Start --- Which localization setting were you using that caused this issue? I assume Spanish (Argentina) --- Quote End --- I have exactly the same problem (Erro : can't change into dir") when invoking file.cl. I am working with version 13.1 of Quartus and SDK, and using the Terasic DE5net board. All the Terasic "tests" example work fine when using the aocx files that are provided. But it is impossible to compile new version of the .cl files. I have tried all the suggestions that were indicated in the previous threads about this issue, without any effect. By the way, the aocl --list-boards command doesn't recognize the board, while the board can be corrected programmed by the Quartus programmers and the matrixMult projects work fine. Thanks for your help.
