Merge simplex transceiver (tx and rx lanes) PHYs in Quartus® Prime Platform Designer on Agilex F014
Hi Winston,
Thanks for your update and clarification that you are using E-Tile transceivers. For your information, due to the underneath architecture, when E-Tile is put to simplex mode, the unused pair (TX or RX) will be powered down. This restriction is tile dependent. Therefore, in the Agilex E-tile, similar restriction should apply. Sorry for the inconvenience. As a workaround, you might want to explore H-Tile if you merging is required.
Chee Pin
- Winston_Sun6 years ago
Hi Chee,
Thanks for your clarification! One more question, when I read the JESD204C intel IP document, it says that Device Support on the JESD204C is Agilex (e-tile) or Stratix 10 (e-tile), shown in the attached screenshot. Does this mean that I cannot use H-tiles for JESD204C? So I can only pick either to merge simplex PHY (H-tiles) or using JESD204C IP block (E-tiles)?
Thanks again,
Winston
