Merge simplex transceiver (tx and rx lanes) PHYs in Quartus® Prime Platform Designer on Agilex F014
As I understand it, you have some inquiries merging of simplex instances. Based on my understanding, the two instance will need to be of the same number of channel. To facilitate the debugging, I would recommend you to start with two 4 channels simplex instances in RTL and try on the merging. Once it is successful, you may move to Platform Designer to try out merging. This would be helpful to narrow down issues if there is any arise.
Chee Pin
Hi Chee,
I tried merging simplex transmitter and receiver PHY (4T4R) and it still gives the same error about pin conflicts. In page 37 of https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_jesd204b.pdf , it says "For simplex variants with E-tile transceiver, the underneath transceiver is in duplex mode. The merging of independent TX and RX within a transceiver channel is not supported in this version",
Does Agilex E-tile supports merging simplex jesd204c transmitter and receiver PHY in the first place? If yes, is there any example designs or documents I can refer to?
Winston
