8 years agoMerge partitions in Quartus Pro - Equivalent of "quartus_cdb --merge"
In Quartus pro 17.1, how can I merge all partitions of a design so that only a single QDB file is needed to reuse this design elsewhere? In Quartus Standard, this could be accomplished via "qu...
8 years ago --- Quote Start --- Hi, Refer the “2.11.4.1 Import and Export Version-Compatible Designs from the Design Flow” & “2.11.4.2 Quartus_cdb Executables to Manage Version-Compatible Databases” From the following link, https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/hb/qts/qts-qpp-handbook.pdf Let me know if this has helped resolve the issue you are facing or if you need any further assistance. Best Regards Vikas Jathar Intel Customer Support – Engineering (Under Contract to Intel) --- Quote End --- Thank you Vikas. I have attempted to do this, but I do not believe the export_design command works when you plan to reuse the design as a sub-partition of another. I hope to merge my entire design into a single QDB file, and then use that QDB file as a sub-module/sub-partition of another design. This is straightforward in Quartus Standard with merged QXP files. When I attempt to reuse the QDB file as a partition after using export_design (as suggested in the link provided), I get the following error: Error (18633): The archive "<my_sub_design>.qdb" contains a full design and cannot be imported via the import_block comamnd nor as a source file in the QSF. I am including the QDB file in the design via: set_instance_assignment -name PARTITION <name> -to <instance> -entity <top> set_instance_assignment -name QDB_FILE_PARTITION <file> -to <instance> -entity <top> The way I was originally exporting the design was via "quartus_cdb --export_partition root_partition" (see https://www.alteraforum.com/forum/showthread.php?t=57908 for more info). The issue with exporting the root partition is that I then need to import that QDB file and QDB files for all sub-partitions in the consumer project.
