10 years agoMemory type for variables
I am modifying the sobel example to find out how to describe the behaviour I want of the system/program. The sobel example has a shift register that holds some of the pixels to be processed. When I change
<type> rows to<type> local rows I get a kernel that is too large to compile. I am doing further tests on performance but this caused me to wonder about the memory types the variables are stored in. I know global resides in external ram and local in on-chip ram, but what about the variables that have no memory-space identifier (if this is the correct term) as the first piece of code?2 Replies
I found a configuration in which the only difference is the local keyword before the rows variable. This uses a little more resources, but the difference in performance (time) is more significant. It is significantly slower, 980us where the non-local runs in 700 us. I think this means the addition of local prevents the compiler from inferring a shift register. If that is the case I assume the first piece of code infers registers and thus is private. Am I correct?
Found what I wanted to know in a online course from Altera.
http://wl.altera.com/education/training/courses/oopncl200
