9 years agoMemory leak using emulator
Hi I'm working on transforming a CUDA program to OpenCL and run on FPGA, right now I'm using the emulator since I don't have the device yet. I wrote a OpenCL kernel that do some simple comput...
9 years agoThanks HRZ
What's still bothering me is why does the memory keep accumulating when I launch it in parallel for each frame? When I use serial for loop the memory doesn't increase as more frames are computed. The same kernel launched with different data input should use the same hardware in the FPGA right?
