16 years ago
Memory Initialization File for multiple RAMs
I'm new to FPGA development and maybe this question is simple, but I couldn't find an answer yet.
I am developing a system with multiple M4K memories which are instatiated inside a generate block over a genvar loop (I'm using Verilog and a Stratix II). For simulation I need them to be initialized with different data. I can specifiy a Memory Initialization File in the MegaWizard but this will initialize all memories with the same data. Is there an easy way to specify a different .mif for each memory?
    yes, slightly edit the generated file, and add a parameter to it.
    Then assign a different string to that parameter each time you instanciate it in the for loop.
    after the memory instantiation add:
    defparam ram_inst.altsyncram_component.init_file = "your_file_here.mif";
    Ok I got it so far. I am using the M4K memory within an other design unit. Here is the simplified code:
    module LocalMem(...);
    parameter cpuid = 0;
    M4K memory (
        .clock(clk),
        .data(m4k_data),
        .rdaddress(m4k_rdaddress),
        .wraddress(m4k_wraddress),
        .wren(m4k_wren),
        .q(m4k_q)
    defparam memory.altsyncram_component.init_file = {"mem", cpuid, ".mif"};
    endmodule
    module TestLocalMem(...);
    LocalMem# (.cpuid(1)) localmem_inst(...);
    endmodule
    This does not work. Within the defparam line, cpuid seems to be empty. No matter what I set cpuid to, the file "mem.mif" gets loaded. I have also tried this to make cpuid the correct ASCII value:
    defparam memory.altsyncram_component.init_file = {"mem", 8'd48 + cpuid, ".mif"};
    but no change...
    Maybe you have another hint for me?
    I found a solution :)
    In case someone has the same problem here is my solution:
    To have a parameter concatenated with a string, it needs to represent the number's ASCII value. Therefore 48 needs to be added to its value. An other thing has to be considered: all chars in a string are represented as 8-bit numbers, therefore the parameter has to be 8 bits wide:
    and
    fixed my problem :)
