10 years agoMemory coding style
Dear all, I've coded two versions of a single-port synchronous RAM with variable read/write width. However, first design results in 1307 ALMs utilization, while second results in 757 ALMs utilizat...
10 years agoWere you deliberatly trying to target ALMs rather than the internal ram blocks? If you were, then have you verified that the code for both is functionally equivolent?
