8 years agoMegaWizard with LPM_MUX runs extremely slowly and is unusable
I'm using Quartus Standard 17.1 on Ubuntu 16.04 Linux. When attempting to generate IP (specifically the LPM_MUX with 2 inputs, 4 outputs), the "MegaWizard Plug-in Manager" opens normally and I ...
8 years agoThis is the same issue we had earlier with the hang of MegaWizard when trying to configure an ALTPLL instance. Probably an issue with Ubuntu's X display.
One simple workaround I found is to start Quartus through an ssh tunnel to localhost with X display forwarding: When you normally start quartus with
/opt/intelFPGA_lite/17.0/quartus/bin/quartus
start it instead with
ssh -Y localhost /opt/intelFPGA_lite/17.0/quartus/bin/quartus
the latter command will reliably avoid the MegaWizard hang (at least for me). No need to rename or reinstall anything.baetis-ma
5 years agossh -Y localhost worked for me too. Thank you very much!!
