8 years agoMegaWizard with LPM_MUX runs extremely slowly and is unusable
I'm using Quartus Standard 17.1 on Ubuntu 16.04 Linux. When attempting to generate IP (specifically the LPM_MUX with 2 inputs, 4 outputs), the "MegaWizard Plug-in Manager" opens normally and I ...
8 years agoHi,
Here is update from Engineering Team. There is no issue generating the 2 inputs, 4 outputs LPM_MUX with CentOS and RedHat. So problem here is Ubuntu specified. To get rid of Ubuntu 16.04 hung issue. 1.Install Java from Oracle. Java version after install is: java version "1.8.0_121" Java(TM) SE Runtime Environment (build 1.8.0_121-b13) Java HotSpot(TM) 64-Bit Server VM (build 25.121-b13, mixed mode) 2. Need to install Quartus in a directory path that has no uppercase letters. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
