8 years agoMegaWizard with LPM_MUX runs extremely slowly and is unusable
I'm using Quartus Standard 17.1 on Ubuntu 16.04 Linux. When attempting to generate IP (specifically the LPM_MUX with 2 inputs, 4 outputs), the "MegaWizard Plug-in Manager" opens normally and I ...
8 years agoHi,
--- Quote Start --- I have discovered that if I'm looking at the first "Parameters" tab and then I very rapidly double-click the Finish button, it will close the dialog and proceed without slowing down. Of course I lose the opportunity to configure anything on the EDA or Summary tabs, but at least I can proceed. Does anyone else running Quartus Standard 17.1 on Ubuntu 16.04 see this same general issue? Can anyone from Intel/Altera respond? --- Quote End --- Yes,Recreated the scenario with Quartus Standard 17.0 on Ubuntu 16.04 environment. I have observed following: Next key after selecting EDA netlist,Check box in summary tab and finish key are not instantly responding.But i was able to generate files after some time. https://drive.google.com/open?id=1dadtzdmcmakwgk5fu521nxd8tuic0xna This is randomly occurring. some time i'm able to generate files with out any issue. Also other IP like PLL are working fine. But the LPM_MUX works fine on windows environment. We will come back on this soon. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
