13 years agomegawizard to qsys integration
Hello I am using Quartus 12.1 , I have generated a custom component using the megawizard Plug-in manager. The custom IP is a Stratix V Transceiver native PHY 12.1. Part of the flow , we can c...
11 years agoHello Mirza
No need for wrapper. If I remember well (it was in 2013) , after the IP is generated, you need to add the path of the generated IP in QSYS : Tools => OPTIONS => IP Search Path => add I have to say that sometimes and depending of the version of Quartus , the software would not always scan properly the added path , sometimes I had to do it a few times. Hope it helps. Cheers Ben
