13 years agomegawizard to qsys integration
Hello I am using Quartus 12.1 , I have generated a custom component using the megawizard Plug-in manager. The custom IP is a Stratix V Transceiver native PHY 12.1. Part of the flow , we can c...
11 years ago --- Quote Start --- Hello I am using Quartus 12.1 , I have generated a custom component using the megawizard Plug-in manager. The custom IP is a Stratix V Transceiver native PHY 12.1. Part of the flow , we can create a new preset file for that specific IP (Stratix V Transceiver native PHY 12.1). When saving the Preset file , the IP configuration interface tells me : "Do you want to add the save path into search Path ?" "Reminder : adding to search path will load this preset automatically next time you launch any project in QSYS" I press YES. The path is indeed added to the search directory path , but I can t see the IP anywhere in the list of available IP. It also gives me the option to add the QIP file to Quartus. I say NO , I want to connect the IP to my QSYS system. Do I need to create a wrapper around my new generated IP (QSYS => New Component...)to be able to see it in QSYS ? or I am missing something ? If I have to create a wrapper , this is fine , but why is the Megawizard including the Preset file in the QSYS search Path ? Thanks for your help. Regards Benoit --- Quote End --- Hi did you have any luck solving this issue? Mirza
