TMich2
7 years agoMegaWizard Plugin Manager becomes unresponsive
Version 18.1.0 Build 625 09/12/2018 SJ Lite Edition (Linux) on Ubuntu 18.04 is working until: Select IP Catalog using PLL as a search, Select ALTPLL, the megaWizard Plugin Manager pops up, chan...
- 7 years ago
Agreed, if it is resized before any input is done there is no lockup. That was my reply 15 days ago...
KennyT_altera
7 years agoHi, can you make sure the below?
1.Install Java from Oracle. Java version after install is:
java version "1.8.0_121"
Java(TM) SE Runtime Environment (build 1.8.0_121-b13)
Java HotSpot(TM) 64-Bit Server VM (build 25.121-b13, mixed mode)
2. Try to install Quartus in a directory path that has no uppercase letters.
3. Right after Megawizard is opened, stretch the window out a little (drag a corner) and make it so scrolling is not necessary.
4. make sure when you launch quartus, there are no error message showing lib is missing.
I was able to duplicate the hang when use workaround 3, it works.
