PSAND2
8 years agoMegaWizard Plug-In Manger Not Working
I'm using Quartus 13.0sp1 Web (free software). Have a project started over a year ago. Have an NCO and FFT. Now, I was going to make a change and the MegaWizard does not work. When editing the NCO, F...
PSAND2
8 years agoI did what you said to do. It still did not work.
I deleted everything that could have been associated with Quartus. I uninstalled everything. Then re-installed.
Still did not work. BUT--
Upset at this I went to the Windows Start Menu, all programs. Under Quartus I found that the MegaWizard is a separate program.
I right clicked and opened the Properties. Select tab Compatibility. (Don't remember every doing this before.) There's an unchecked box. I checked the box and then selected Windows 7. At the bottom there is another unchecked box. I checked that box which says -- Run this program as an administrator.
MegaWizard works -- at least by itself. Now I have to start Quartus and see if it works from there.
