12 years agoMegawizard Plug-In Maneger can't open ALTDDİO_OUT megafunction
Hi everyone,
I'm using Quartus II 13.1 (64-bit) and my OS win7. I want to add ALTDDIO_OUT to my project,but ALTDDIO_OUT's interface does not open in any way.Can someone help me?4 Replies
I have the same problem. I am tryin to implement "Using Triple-Speed Ethernet on DE2-115 Boards" tutorial to test the ethernet connection, when I come to try to create a new megafunction using IP Catolog (Basic Functions > I/O > ALTDDIO_OUT), the megafunction wizard does not open. Thank you. - Altera_Forum
Are you using the Quartus II 13.1.0.162 version? Are you only having a problem when opening one IP address or all the IP addresses?
Please refer to the link below, follow their steps, and see if it helps you resolve your problem. https://www.youtube.com/watch?v=v4pxyaqtmng&feature=youtu.be - Altera_Forum
I have same problems. Doesnot open Megawizard windows with attempt add function "PARALLER_ADD".All other function (i try run 8-10 different function) work correctly.
Quartus16.0, Windows 7. - Altera_Forum
--- Quote Start --- I have same problems. Doesnot open Megawizard windows with attempt add function "PARALLER_ADD".All other function (i try run 8-10 different function) work correctly. Quartus16.0, Windows 7. --- Quote End --- All is OK. Problem is solved. It is antivirus problem.
