11 years ago
Megawizard Core Generation Error
I have problem with megawizard. While im trying to generate pcie express ip, i get these errors.
--- Quote Start ---
Error: asd: set_parameter_property: No parameter gui_pipe_rlv_checking_length while executing
"set_parameter_property gui_pipe_rlv_checking_length ENABLED $sup_run_length"
(procedure "common_parameter_validation" line 19)
invoked from within
"common_parameter_validation "
(procedure "validation_callback" line 3)
invoked from within
Error: add_interface_port: input not allowed for Direction, must be in {[Input, Output, Bidir]}
Error: asd: get_parameter_value: No parameter mgmt_clk_in_hz
while executing
"get_parameter_value mgmt_clk_in_hz"
invoked from within
"expr [get_parameter_value mgmt_clk_in_hz] / 1000000"
invoked from within
"set_parameter_value mgmt_clk_in_mhz [expr [get_parameter_value mgmt_clk_in_hz] / 1000000]"
(procedure "elaboration_callback" line 5)
invoked from within
Error: add_parameter: integer not allowed for EParameterType, must be in {[INTEGER, NATURAL, POSITIVE, BOOLEAN, STD_LOGIC, STD_LOGIC_VECTOR, STRING, STRING_LIST, INTEGER_LIST, LONG, FLOAT]}
Error: add_parameter gui_pipe_rlv_checking_length 160 : null
Error: altera_xcvr_pipe: set_parameter_property: No parameter gui_pipe_rlv_checking_length
while executing
"set_parameter_property gui_pipe_rlv_checking_length DEFAULT_VALUE 160"
(procedure "common_add_parameters_for_native_phy" line 208)
invoked from within
"common_add_parameters_for_native_phy "
(file "C:/altera/14.0/ip/altera/altera_pcie_pipe/xcvr_generic/altera_xcvr_pipe_hw.tcl" line 109)
--- Quote End ---
Any suggestions?
Thank you.
