8 years agoMax+Plus II with parallel T-Guar, missing license file
Hello first. We made years ago a FLEX8000-Design with Max+Plus II. Now we need to do a slight change in the design, but we can not find our corresponding license.dat in our inventory. With the Bas...
8 years agoHi Sersa,
You cannot simply modify the license.dat files, what you need to do first is go to self service center to see if you can generate the license.dat base on your dongle number. If you cannot generate the license, you need to contact the customer service in the same page. you can go to https://www.altera.com/ click on support -> self service licensing center Thanks, Best regards, kentan (This message was posted on behalf of Intel Corporation)
