Maxplus Graphic Editor
Graphic Editor
I have installed MAX+PLUS II Baseline.
I got licence.dat file from Altera support. I put this licence.dat file in the root directory of MAX+PLUS II software.
I opened MAX+PLUS II software, I choose File-->New, pop up window appear, I select Graphic Editor, then OK. I got th emessage:
"Current license file support does not include the 'Graphic Editor' application or feature."
Do you know why is this error apeared and where licence.dat file needs to be put, in which directory.
I would apprecite your promt reply.
- AndrewG_Intel
Hello @Chano0219
Thank you for posting on the Intel® communities.
We understand that you have some inquiries regarding Intel® FPGA MAX+PLUS II Software. We have a forum for those specific products and questions so we are moving it to the Intel® FPGA Software Installation & Licensing Forum so it can get answered more quickly.
Andrew G.
Intel Customer Support Technician
- Nurina
The error means that the MAX+PLUS II software cannot find your license file.
Make sure your license.dat file is saved in the MAX+PLUS II BASELINE software installation directory. Then do the following steps:
- At the Options menu, choose License Setup.
- Specify the license file by clicking Browse. In the Directories box, go to the directory where your license.dat file is located, select the license.dat file in the Files Box, and click OK.
- If you look at the Available Features box, it should contain Graphic Editor.
- Click OK to save your changes.
Let me know if this helped.
Nurina
- Nurina
We did not receive any response to the previous question/reply/answer that I have provided, thus I will put this case to close pending. Please post a response in the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
Nurina
P/S: If you like my comment, feel free to give Kudos. If my comment solved your problem, feel free to accept my comment as solution!
