ESkul1
6 years agoMAX10 set_false_path failure
Attempted to add CDC module (VHDL) with the following attributes applied (taken from Intel/Altera example): ATTRIBUTE altera_attribute : string; ATTRIBUTE altera_attribute OF ff1 : signal is "-...
ESkul1
6 years agoHI KTan, re this issue, your advice got this resolved.
I have another issue open, re. a AVSPI core I generated in QuartusII, that fails to compile -- error on attributes inside one of the core files.
Someone picked this up but have not heard back for over a week.
If you are able to take a look, it is here:
https://forums.intel.com/s/question/0D50P00004Ye0HJSAZ/avspi-core-attributes-failure
Thank you for your time and help.
