ESkul1
6 years agoMAX10 set_false_path failure
Attempted to add CDC module (VHDL) with the following attributes applied (taken from Intel/Altera example): ATTRIBUTE altera_attribute : string; ATTRIBUTE altera_attribute OF ff1 : signal is "-...
KennyT_altera
6 years agoOur advise is always use synchronous reset, if you have asynchronous reset, you can synchronize it with the below method:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/qts/qts_qii51006.pdf
page 12-8
