9 years agoMAX10 .pof programming fail
Hi all, I'm trying to program .pof file in MAX10 of our custom board but it fails with the following messages: Info (209060): Started Programmer operation at Wed Sep 13 10:31:58 2017 Info (...
8 years agoHi Giuseppe,
I am experiencing the exact same problem with a MAX10M50. My programmer window is just like yours in your attached image. I do not see the CFM1 or CFM2. I can program the .sof, but can't get the CFM to pass. In fact, I have an LED driven (via transistor) from the DONE pin and I can see Done Flash once very short and again for around 250ms before the operation fails. I tried to turn on the "Enable real-time ISP to allow background programming" from the programmer, but that causes the programming operation to fail sooner. Can you provide any more insight? Thanks, Mike
