9 years agoMAX10 .pof programming fail
Hi all, I'm trying to program .pof file in MAX10 of our custom board but it fails with the following messages: Info (209060): Started Programmer operation at Wed Sep 13 10:31:58 2017 Info (...
9 years agoHi all,
we have solved: the problem was the point "To enable the real-time ISP mode, turn-on the Enable real-time ISP to allow background programming" but IMHO tha Altera documentation is not so clear; in fact if the MAX10 is green (never flash pragrammed), the .pof programming works only if you first program .sof file. Hope it helps someone. Bye, Giuseppe
