BOnor
7 years agoMAX10 GPIO Lite DDR Output Sim
I've run into the follow error while initializing an Aldec simulation: ELBREAD: Error: ELBREAD_0081 fiftyfivenm_atoms_ncrypt.v (732): Design unit protected_97b98e91bb4cae2ac97c0cd96c2469e5 instantia...
MuhammadAr_U_Intel
Contributor
7 years agoHi Brian,
Please note the version of ALDEC simulator tested with Quartus.
https://www.intel.com/content/www/us/en/programmable/documentation/gtt1529956823942.html
Table 1. Supported Simulators
Since you mentioned you are able to simulate GPIO Lite Single input FF, I am suspecting above Error message is due to missing Libraries
Can you try following.
- Use the auto-generated simulation script to bring up IP simulation.
If the issue still persists you can share further details with me to take a look.
- Quartus Version used to Generate IP and simulation libraries.
- What version of ALDEC simulator are you using ?
- GPIO settings (If possible share the project archive)
- What steps did you followed to replicate Error ?
Arslan
