NM8
7 years agoMAX10 FPGA Pin Assignments for LVDS signals input and outputs
Hi, We are using MAX10 FPGA(10M40SCE144C8G) with our board. We want to connect multiple input and output LVDS signals to one of the banks of this FPGA. To use the true LVDS (TX or RX) should we use...
- 7 years ago
Hi Nanjunda,
I tried to replicate scenario & I observed the below results,please try to implement same at your end & if you have any different issue,let me know,
please find the below link & attachments,
https://www.intel.com/content/www/us/en/programmable/documentation/sam1394433606063.html#sam1394435423058
Vikas
Vicky1
7 years agoHi Nanjunda,
I tried to replicate scenario & I observed the below results,please try to implement same at your end & if you have any different issue let me know,
Vikas
- NM87 years ago
Hi Vikas,
Not sure what you are referring to in the link above.
Are you referring to "Intel MAX 10 LVDS SERDES I/O Standards Support " heading?
I do want to use the True LVDS & I'm clear with the pins to be used for it.
Just that confusion whether to give VCCO=2.5V or 3.3V.
I hope you can clear it. If you recommend to use 2.5V, why not 3.3V and what would be the signal characteristics with 3.3V VCCO.
Thanks & Regards,
Nanjunda M
