MAX10 FPGA Pin Assignments for LVDS signals input and outputs
- 7 years ago
Hi Nanjunda,
I tried to replicate scenario & I observed the below results,please try to implement same at your end & if you have any different issue,let me know,
please find the below link & attachments,
https://www.intel.com/content/www/us/en/programmable/documentation/sam1394433606063.html#sam1394435423058
Vikas
Yes, you can. I have compiled an LVDS design using both LVDS Tx & Rx @ Bank3 and IO Standard set to 3.3 V LVCMOS. But make sure to set all other pins in the same Bank to the same voltage standard.
The design I used has single-ended signals also at the same bank set to 3.3V LVCMOS.
Can you post the compilation report file here.. so we can take a look and see whats wrong. As well as the pin assignments file QSF.
- NM87 years ago
Hi Abe,
Thanks a lot for your inputs.
"I have compiled an LVDS design using both LVDS Tx & Rx @ Bank3 and IO Standard set to 3.3 V. But make sure to set all other pins in the same Bank to the same voltage standard."
I tried the same thing. My experiment results are as below:
- With just LVDS TX & RX with VCCIO=3.3V - Compilation passed
- Along with '1' I added 1 input single ended (defined as 3.3V LVCMOS in Assignment editor) signal to the same bank - Compilation passed
- Along with '2' I added 1 output single ended (defined as 3.3V LVCMOS in Assignment editor) signal to the same bank - Compilation failed.
Got an error saying there is no IO voltage compatibility between the IO pins.
According to your statement above, we are still working all at 3.3V level, yet we get a error which says we are not right.
Could you give me some confirmation on this please?
Thanks & Regards,
Nanjunda M
