MAX10 Differential HSTL-1.8 for MIPI CSI2 TX
Hi AminT
thank you for your reply.
Indeed the document specify the VOL/VIH ranges, but it seems not referring to which set of IOs support Differential HSTL.
Is there any clarification on that?
Would all the pin marked as DIFFIO / DIFFIO_TX / DIFFIO_TX_RX support Differential HSTL?
Thank you
It depends. You may refer to pin-out files from this link of your device: https://www.intel.com/content/www/us/en/programmable/support/literature/lit-dp.html
Thank you.
- luca55 years ago
Hi Amin,
thank you for the hint. For instance, that means pins marked
DIFFIO_RX_L5n
DIFFIO_RX_L6nare not differential TX/RX but just differential RX capable pins, correct?
Thank you
- AminT_Intel5 years ago
Yes you are right!
