MAX10 10M08 intermittently failing to program with Quartus
Apologize for the misunderstanding on my previous response as I did not know that you have tested on few other computer and not successful.
I found a similar issue that has been addressed previously, please take a look and let me know your feedback.
https://community.intel.com/t5/Intel-Quartus-Prime-Software/MAX10-pof-programming-fail/td-p/243893
Aiman
Aiman:
That sounds very similar to the problem I am experiencing except I match best with what the last poster described and that post was never resolved. This is an FPGA that I have flashed multiple times with a sof and also with a pof but the programming success is very infrequent. It seems like a Quartus driver bug or something but could possibly have something to do with the board or IC I suppose though that seems like it should be unlikely since this is the eval board. I experience the problem using example code so I think I have ruled out the design itself being flashed leaving only the options, way it is executed in Quartus, or Quartus itself.
